Had a phone call from Fiat UK and I felt totally fobbed off. They kept saying that they know what the problem is and were just waiting on an advisory to come out of Turin on how to fix it. My dealer is adamant that they do not know what the problem is which is why Turin took ownership of the problem in the first place.
Apparently the car has been through about 6 litres of oil in the first 1000 miles the car has been driven which horrified me. I knew they had been filling it up each time the car went in recently, but didn't realise it was that bad.
I've told the dealer and Fiat UK that if a fix isn't forthcoming, and soon, along with a guarantee that the future trade-in value won't be compromised because of this issue, I am rejecting the car.
The head of Fiat UK's customer services department is calling the dealer tomorrow and they'll be calling me after.
Hmm, when I started reading your thread I thought to myself that the only time petrol engines blow out smoke is when they are burning oil - but you said in your first post that the oil levels were ok.
I was also a bit worried when you said the dealer told you it was using a cupfull of petrol on start up because of a blocked tube, this doesn't sound right to me - more likely it was dumping unburnt fuel through the exhaust system which is not good for the cat
Now it appears it has used 6 litres of oil in 1000 miles which raises my first question - is it burning oil on start-up? Maybe a bad oil seal or a piston slightly below tolerance? Both of which would require an engine stripdown which obviously the dealer won't due without permission from FIAT - did the dealer tell you they had topped up the oil so much or have they kept you in the dark?
