Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Fuel filter change 1.3 multijet<!-- google_ad_section_end -->
Fiat Punto evo - euro 5
Published by rmcas
27-01-2019
Difficulty Level: 2
User Rated:Unrated
Post Fuel filter change 1.3 multijet
Hello everyone, this is my first guide.
While the task isn't too difficult I thought I'd make a guide anyways, At least it lets people prepare upfront for the job.
Equipment needed:
  • Plastic gloves
  • 10 mm socket
  • small plastic tube
  • diesel filter (the one i got: F 026 402 074, Bosch)
  • reservoir to dispose the old diesel + old filter
  • cleaning wipes/paper
Step-by-step
Step 1 - remove old filter
Step 2 - install new filter
Step 3 - fill new filter with diesel
Step 4 - finish up
It is important to use gloves to prevent getting your hands wet with diesel. Many people do it I know, but it's still not good for the skin. read further
https://www.who.int/ipcs/emergencies/diesel.pdf
The two diesel connectors on top can be easily removed. They unlock when finger pressing (squeezing) the connector body.
Remove the bolt, be careful not to let it fall on the engine bay. Lift/rotate slightly the filter with one of your hands, locate the electrical connector underneath and remove it. BE CAREFUL to prevent diesel fluid falling inside the connector housing, contacts, etc. At this moment the filter is completely full and it will leak diesel when leaning the filter even a small angle.
If you wish to recycle the diesel, this is the moment to empty the filter on a container/bottle/etc.
When the filter is empty, you can remove the sensor by unscrewing it. Here you can also sense what kind of torque it needs in order to get it tight again on the new filter.
Don't worry about the little rubber ring, there should be a new one in the new filter.
pics:
Filter before being removed. red arrows: bolt and sensor. on the topside of the filter we can see 2x diesel connectors and the venting bolt (assy?)
Name:	2019-01-11 14.23.58.jpg
Sensor + sensor connector before being disassembled
Name:	2019-01-11 14.24.07.jpg
Filter bracket locking's location. The other fixation point is the bolt.
Name:	2019-01-11 14.24.16.jpg
Diesel filter location on the engine bay
Name:	2019-01-11 14.24.26.jpg
Before you disassemble, just notice this poke yoke system. This needs to be taken in account when assembling the new filter.
Name:	2019-01-11 14.24.39.jpg
Make sure the new filter is clear.
Remove the bottom plastic cap, install the existing sensor. I've tightened mine just with hand, have no clue on how much scientific torque needs to be put in there. Just tighten it enough (no gorilla force on this one ok?)
Connect the sensor to it's electrical connector. Place the filter close to it's final position (one hand) - notice the poke-yoke position as on the images. Get the bracket in position (another hand) and place the bolt in position and turn it (yet another hand - but you're gonna manage )
Adjust the filter to its final position - rotation and height - and fully tighten the bracket bolt.
Remove the rubber caps from the new filter and install each of the diesel connectors. MAKE SURE IT CLICKS ON EACH OF THEM. I didn't do this and later on a small diesel shower took place.
The new filter is installed but DONT START THE CAR YET!
pics:
new filter
Name:	2019-01-11 14.28.18.jpg
topside of the new filter
Name:	2019-01-11 14.28.22.jpg
bottom side of the new filter
Name:	2019-01-11 14.28.26.jpg
new filter and existing sensor, before assembly
Name:	2019-01-11 14.29.32.jpg
new filter - sensor rubber which came with the filter
Name:	2019-01-11 14.29.49.jpg
install process - electric sensor connected
Name:	2019-01-11 14.30.48.jpg
install process - bolt in place but filter not on its final position, bolt not tighten yet
Name:	2019-01-11 14.31.58.jpg
points of attention: 2 point bracket mount + poke yoke for filter position
Name:	2019-01-11 14.32.07.jpg
close-up on the poke yoke system
Name:	2019-01-11 14.32.26.jpg
Step 3 - fill the new filter with diesel
The new filter is empty and must be filled up before starting the vehicle.
To do this I've unscrewed the ventilation bolt few turns (2x i guess), and connected a small flexible hose routed to a small bottle. This bottle was placed close to the windshield on a place where I could see from the driver's position.
To fill up the filter: turn on the ignition key and wait 10 seconds. do NOT crank!!
repeat the ignition cycle few times until you see diesel coming on the bottle. this means that the filter is filled in with diesel and has no more air in it.
I recommend to wait few seconds between ignition cycles to avoid over-temperature of the glow plugs. I'm not sure if they're gonna die of this, but better safe than sorry.
Close the vent screw on the filter and remove the hose and bottle.
you can now crank the engine. If all went well there should be no issues.
pics:
Vent screw with the small flexible hose installed
Name:	2019-01-11 14.36.31.jpg
flexible hose route and bottle
Name:	2019-01-11 14.36.49.jpg
closeup on the bottle with some diesel in it after venting the filter.
Name:	2019-01-11 14.36.53.jpg
if you have comments or improvements please let me know, I'm happy to hear from you. English isn't my mother language so apologies in advance if it isn't exactly perfect.
Good luck!
Thanks Detroitdiesel thanked for this post
Likes Skywalker1973, varesecrazy liked this post
Old 27-01-2019   #1
varesecrazy has donated!
Re: Fuel filter change 1.3 multijet
Well done.
I wrote out a basic guide for the GP.
But a different pipe arrangement and filter on that mj.
Doing another soon so will add more pics
Charlie
Likes rmcas liked this post
Old 28-02-2021   #2
Spain
great contribution. but I have a problem when doing all the steps of your tutorial in the warning light it lights up water in the diesel. What should I do?. Thank you.
Skywalker1973 is offline Reply With Quote Quote
Old 28-02-2021   #3
Quote Originally Posted by Skywalker1973 View Post
Hi..
Check the wiring to the lower sensor
I suspect it is the same sensor as my old 2007 mj..
You can read the fault code and try to clear it
Old 02-03-2021   #4
Spain
I have checked the tubes. If I remove the electrical connector with the ignition on and I start the error is removed.
If I turn off the car and connect the electrical connector, the error returns. You don't have to run it through a computer to remove the error, right?
Old 02-03-2021   #5
I bought a filter assembly with sensor for 10 from a breaker..
Newly swapped sensor fixed it
Likes Skywalker1973 liked this post
Comment
Search this Guide:
(G) Multijet diesel fuel filter change parkys100 Panda 22 09-07-2012 12:35
(T) Multijet Fuel Filter NottsCharger Panda 2 16-02-2011 17:59
(G) Fuel Filter 1.9 Multijet fronteratech Doblo 3 28-11-2010 15:48
(T) 2.0 20v cambelt change help and fuel filter change help Wilqaeda Marea 4 13-10-2009 12:20
(T) 1.3 multijet fuel filter sconebum Doblo 11 11-07-2008 14:58
