Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Change the bulbs behind the HVAC control unit<!-- google_ad_section_end -->
A lot of time and effort is needed to replace just 2 bulbs!
Published by Normy19
11-05-2018
Difficulty Level: 2
User Rated:Unrated
Post Change the bulbs behind the HVAC control unit
How to change the HVAC control unit bulbs
Items you will need:
1 x set of radio keys
1 x needle nose pliers
1 x flat screw driver (for prying, or use prying tools)
1 x torx screwdriver (not sure on size bit)
2 x New replacement bulbs
Disconnect the battery. Remove the radio from the dash using the radio keys and a flat head screwdriver for prying, mine was quite stuck and needed lots of prying to come loose. Be careful to not mark the surrounding centre console.
ID:	190715Click image for larger version
ID:	190714Click image for larger version
ID:	190713Click image for larger version
With the radio now out, begin removing the housing by removing the torx screws that hold it in place. There are 7 in total.
Remember to remove the screw in the right side wall. The housing can now be removed by simply pulling it out. It is held in place by two clips at both top corners (need a quick sharp tug to remove).
Now the housing is removed, push down on the orange/red lever on the connector to remove it from the socket.
Remove the cable from the housing by squeezing and pushing the black plastic clip though the metal frame, this helps to keep the area tidy and not risk snapping wires due to the housings weight etc. Its quite tricky.
Tie/tape the wires up to keep them away from the HVAC control unit, as this helps a lot. First, remove the top two screws that hold the HVAC unit in place, then remove the two that are under a black plastic piece of dash, near the cupholder under the bulging out part of the bottom of the centre console (Just feel under and pull off a little black panel). I used a torx bit and the corresponding ratchet bit to get the two torx screws loose and then finished unscrewing by hand. The left screw is the hardest to remove as the lip of the cup holder is in the way.
Now, next to where you removed the top two screws, use the flat head screwdriver to push in the plastic clips that hold the HVAC unit in place.
With the HVAC unit free, push it in and tilt it up to see the bulbs at the bottom, in-between the dials
Using a flat head screwdriver, remove the wires from the wire holder/tidy clips on the back of the HVAC unit.
Using needle nose pliers, grip the grey bulb socket (NOT THE WIRES) and pull (quite hard) and the bulbs should pop out.
ID:	190703Click image for larger version
Swap the bulbs with the replacements, and then connect the battery and test to see if they work before putting them back into the HVAC control unit.
ID:	190717Click image for larger version
Just follow the instructions backwards to put everything back again. When you come to put the radio back in, you’ll notice there is a large black plastic piece on the back of the radio. You’ll need to ensure that this can freely fit back into the hole in the back of the radio housing, and that no wires are in the way, otherwise the radio will not fit back in. I found the best way is to push all the cables to the left, and then connect the radio to the cables very close to the housing, and then slowly push back into place. It may take a few times to get it back in so its flush to the rest.
Thanks Detroitdiesel, CRJ 127, varesecrazy thanked for this post
Likes Andi9386, CRJ 127, varesecrazy liked this post
Old 13-05-2018   #1
varesecrazy has donated!
Re: Change the bulbs behind the HVAC control unit
Excellent guide. Thanks.
Old 29-10-2018   #2
Netherlands
Great guide with excellent photos, thanks for this
Does the Punto Evo use T5 286 bulbs just like the Grande Punto? Not sure what bulbs to buy.
I bought my car with no lighting of the HVAC unit at all so I am wondering if the fuse blew, gonna check that first as soon as I find out which fuse it is.
Likes Normy19, varesecrazy liked this post
Detroitdiesel is offline Reply With Quote Quote
Old 18-12-2018   #3
Normy19 has donated!
Hello! I'm glad the guide has helped you.
Yes, I used T5 286 bulbs for this as that was what was already in there.
Hope you were able to get the problem fixed
Normy19 is offline Reply With Quote Quote
Old 25-03-2019   #4
Netherlands
I finally got around to changing the bulbs out.
The next time I'll probably only remove the radio and it's housing. My bulb fittings were quite loose so if I had know exactly how it looked back there I should have been be able to change them out by just sticking my hand in the hole.
On a sidenote for anyone following Normy19's guide: DO read the part about the black plastic piece of dash trim near the cupholder that you need to remove to get to the two screws. If you don't you'll spend an hour upside down removing the wrong two bolts and nearly rip the HVAC unit to pieces thinking it should be able to come loose.
Likes varesecrazy, Normy19 liked this post
Old 11-07-2019   #5
Finland
Hello, thanks Normy19 for the great instructions. I had read some other instructions how to change these bulbs but those didn't work. Then I found your explanation, followed it and it worked! The job was actually quite easy, only one bolt at the bottom was a bit complicated but I survived. Next time I'll probably do this job within half an hour but hopefully I won't need to do this very soon again, edges are quite sharp
Likes Normy19 liked this post
Buongiorno is offline Reply With Quote Quote
Comment
Search this Guide:
(T) How to replace heater control bulbs SorenMarodoren Punto Evo 15 13-05-2018 08:35
(G) Uno 1.7D 5D HVAC electric motor eby Uno 3 21-01-2014 14:52
(G) Climate control unit change Karolis92 Stilo 2 13-01-2013 16:59
(T) Heater control bulbs Big Black Stilo Bravo 4 10-03-2010 21:26
