ThinkQuickly
- Joined
- Feb 7, 2006
- Messages
- 11
- Points
- 3
maybe someone can help...
I have a 1978 Fiat Spider 124... the lighting system that has "gone mad".
Symptoms:
the blinkers flash when the headlights are off, but both sides of the lights flash, even if i have the blinker like i'm turning left....
the blinkers do not flash AT ALL when the headlights are on...
the drivers side rear blinker light stays on when the lights are on...
passenger side rear parking light is not working (i'm american, driver is on the left).
what i've done to fix:
i changed the flasher for the blinkers. (maybe i bought the wrong one?)
i checked all the fuses; they're good.
i put brand new light bulbs in EVERY socket in the external system.
ALSO:
i found some blue oil filled thing underneath the dash; it had wires going into each end... it was loose (unscrewed), and oil was leaking.
i opened it up and there is a fuse looking thing with copper wire coiled around...the wire is broken. i think it's some sort of oil-filled fuse, but not sure. does anyone know what this is???
and any ideas why my light system is acting so weird?
Symptoms:
ALSO:
