Technical flywheel lightened, where?
Where can I get a 1.2 16v flywheel lightened?
Any idea of cost?
Please, somewhere that knows what they're doing as I'm attached to my feet :)
You coult try dropping it off at the local hairdresser, estate agent, financial consultant, wine bar etc. Alternatively, Yellow Pages under Engine Reconditioners, Precision Engineers, Folk From Up North with Big Lathes, etc.:bang:
Sorry couldn't resist that, although when I was t lad there were two engineering shops locally, when I scanned the local yellow pages the nearest was 20 miles away......
Thanks for the picture and a target weight, very useful.
South East Asia, they have an engineering shop on every corner :p -big hammer and arc welder :)
Tried the hairdresser he suggested I came back when it was quieter for some flywheel relief? So I've popped into the wine bar to wait.
TBH I was hoping you could recommend someone reliable that deals with Fiat stuff, I would use Old School but, he seldom replies to mails so I wonder how long before my flywheel would get back.
"Waiter! More Chardonnay" :devil:
(y)
It doesn't need to be a Fiat specialist, any decent machine shop that does dynamic balancing should be ok. I'm not sure where you are in the SE, but Oselli at Oxford are very reputable and have some guide prices on their website. Alternatively Burton, although they're a Ford specialist, may do it, and certainly would recommend someone if they can't. Give 'em a call.
Best of luck,
John
Basically what the machine shop will be looking to do is to remove weight from the outside of the flywheel. Drastically removing material from the centre weakens it, and has less effect. It isn't about removing as much weight as possible, but where it came from matters. Obviously they can't just carve from the outside at will, as its helpful if the starter ring gear remains attached.
wibble.
Seems most are routed out to a certain extent. Is it not possible to also drill sections out, ie, through the whole flywheel to reduce even more weight.
I read some cars have alloy/alu flywheels available that in comparison weigh pretty much nothing, are they available for the fire engines? Not sure I'd want one too light though!
KRistian
no, you need the clutch contact plate on the flywheel to be intact don't wanna go drillin that!
also you don't wanna weaken it really
What i have read (not had a FW lightened myself....yet) that you shouldn't use a lathe cut face for the clutch but a ground face, although this is from race engine builders advice, so my be ok for road use. So ask at the machine shop if this is something they can do.
Anyone thats had one lightened, what process was done on yours? lathe or grind?
Reason is, i have a lathe..... :D
