Do you fancy a Cinqy
Hello all you experts ~ new member/owner here needing a bit of advice. Where can I take a live feed easily from the ignition switch that will turn off the radio with the ignition. On our '96 Cinqy S the white 6 way connector block under the dash has a permanent live connection which is o.k. for the radio memory. The other live wire from the radio which should go to ignition is connected to that as well, so you have to remember to turn off the radio manually when leaving the car.
