Technical Injection Pump - Bravo
BICHODUMATU
Hello! I have a Fiat bravo Td100 and it has a VG turbo but the injection pump can't provide enough fuel for the power of the turbo so i am looking for a way to solve that problem. Changing the pump to a bigger one but i don't know wich are compatibles or else changing the head on the pump. Can anyone help me?
Thank you very much
i assume you've tried increasing the standard pump's output? there's usually a screw on the pump to adjust it (not sure if fiats are the same?).
alternatively i know the pump from a peugeot 306 TD can be turned up a lot, so maybe you could try using one of them
I've already increased fuel debit, the injection pump is on it's maximum...
I will make a "transformation" on the diesel pump....
When i get the car ready i will tell you. Thank you
