Hiya,
I've just picked up a 2001 sporting and found a couple of faults. The cd changer don't work...not a biggie, will just get rid.
The air-con pipe is broken....does anyone know rough cost of getting it re-gassed?...(I know the pipe is about £40).
When the engine is on, there is a noise, like running water from under the passenger side...is this due to the broken air-con?
The other thing that is a bit of a worry is the heater fan doesn't work and when you switch it on, it turns the dashboard and head-lights on.
Any help would be great. Thanks
