karmapolice
Ive got a Fiat Punto 55sx N reg and the fuel injector warning light is more,more or less permantly on(on the dash).When the warning light is on it drives like crap,between 2000-3000 revs you have to thrash it to get anywhere.As soon as light goes out its fine.Does it sound like a Lambda sensor problem to you because the warning light is too precise..warning light on, problem..off fine?If so where exactly is the sensor..i've read up in this great forum and had a look for it but cant be sure where it is..Under the car by the cat? or just on the down pipe infront of the engine..or could it be a carb or catalytic convertor problem.
You guys are my last hope.
thanks in advance
Karmapolice
thanks in advance
Karmapolice
