Bigbadtez
Hi to everyone!!! Right ive browsed your posts and i need a firm answer on this question.Ive just purchased a Punto 55 sx 1.1.Its a 1996 model which i think is the mk1.Its the first time ive owned a Fiat and if i dont get this sorted it will be the last i think!!When i bought the car it only came with one blue key and no red.Anyway after getting it home ive noticed it ticks over at random revs ie:900 then 1100 then 1000.I tried to clean up the throttle body and linkages and checked the throttle cable for snagging.Still got the problem.So i checked the Lambda sensor with my multi meter and found the values bouncing between 0.30 and 0.80 when warm.Is this right or should the values be different?I want to dis connect the battery to do an ecu reset but will the car start back up after without the red key?I really would appreciate your help as i am new to the Fiat world.
By the way GREAT forum and very helpfull!!
