General Panda Turbo
General Panda Turbo
fudge
United Kingdom.
Hello everybody, got hold of a uno turbo on saturday but want to put in into a panda i've owned a couple but didnt pay that much attention to the mounts wish i had! will the 1.4 bolt straight in loom and that dosent bother me i just want to get the engine into a panda as soon as, and **** on the like! anybody know of anysites that do feature a panda turbo Thank you all Keep pandas on the streets
The turbo engine isn't from the same engine-family. It will need new mounts. Also it won't fit the standard gearbox, you'd need to replace that as well. While you're at it, you might as well replace the brakes. :)
|| GONE IN 60 MINUTES ||
I already tried and it won´t "easily" fit but hey anything can be done if you work at it.
You should also change:
-Brakes: they´ll fade rather quickly with that kind of power
-wheel bearings: chances are they´re shot
-Suspension: heavier car stock won´t do Y10 is a good option but it will sit lower at the front.
-Tires: go with wider tires to be able to put the power on the pavement or you will find it just spin horribly.
I guess that this covers most that should be done.
I was just wondering if this swap went anywhere?
_____________________________________________________________
If you have any questions don´t be afraid, ask away. I´ll be glad to help.
If i´m online you can try my site, it´s mostly storage http://www.smokeme.ipupdater.com/everything
