Problem with a corroded upper offside suspension spring plate cup. The rubber bump/ bung metal retainer that is suspended from the top plate metal cup and sits inside the rear spring has a rusted cup and has dropped inside the spring. There are no handling problems and all is ok. Is it there to stop the spring bottoming when fully loaded? How can it be replaced? Is the part available thro Fiat? The top plate is not corroded and the spring mounts both ends are good, its just this cup thing thats rusted.
Welcome some advice.
tinpan
tinpan
