Right, I'm half way through this job, but can't work out how to do it. I've removed the wing mirror, removed the arm rest, freed the fabric, and freed the white paper stuff. How do I remove the fabric completely? It's stuck at the top.
I can't remove the door handle completly either the rod is in there, but I can't take the rod off. It looks like the things should just squeeze together and push through, but they won't go through, and the plastic bits are getting very damaged now.
Workshop manuals aren't much good really because nothing shows how to do this on a Sei.
Do I also need to replace the inner door seal thing as well, or can the outer be replaced on its own?
I have a Seicento SX (1999) btw. Hopefully I will be able to fix this today.
