fimmo
i know most cinqs have this annoying flat spot at 3000 revs! finally i've cured mine! i fitted a k+n 57i kit to it to try and sort this it helped but it was still there! then i discovered the breather pipe from the cam head to filter was getting a bit of condesation in it and blowing back into my k+n and injector! so i removed this pipe filled the hole in the filter and fitted the original breather pipe then cut the pipe about 2.5 inches from the cam head and fitted a breather sock to it! no more flatspot? by the way the k+n breather pipe is hollow but the fiat one has some metal gauze to stop oil blowing thru the pipe!,only prob is now i have a faint smell coming thru my vents when the fan is on! but i'll extend the breather pipe so it breathes out the bottom of the engine bay as opposed to breathing into it!
WHEN THIS BABY HIT'S 88...YOUR GONNA SEE SOME SERIOUS s**t!
