Had check engine light come on our 1.2 (2009 UK)
Wife was driving at the time and felt it almost stalled and felt rough, two error codes come back. She stopped the car filled up with fuel as almost empty but at least 70 miles left, so wasn’t running on 0 miles. After restarting the car it was fine but check engine light remained
P0120 - Throttle/Pedal position sensor
P0300 - Random/multiple cylinder misfire
Spark plugs were changed around 10 months ago, battery a year or so
Codes cleared and went for at least an hours drive and been fine, no misfires and worked as should.
I was thinking tomorrow to check all the ignition cables so check their condition, but if I remember correctly they looked like new condition (when I changed the spark plugs months ago)
Car has only done around 29K since new.
I’m guessing it’s a wait and see if it happens again and check codes again, as I don’t know if either of them are old stored codes or both happened at the same time.
Is there anything else I can visually check?
