Technical Punto Sporting air filter intake pipe
Burntwood, Staffordshire
Does anyone know where I can find one of these (7786450)?
Everywhere I look they are out of stock. Every picture I see of an engine bay has the hose taped up (including mine)
Surely someone must have a decent one, new or used.
If not, does anyone know the feasibility of having one 3D printed? Or if there is an alternative? I have looked at silicone hose, but with four different sized outlets, I am not sure how this would work. This is an inlet hose to the air filter so a cone filter on a pipe would not work. I have checked out previous threads on the forum and haven't found a solution suitable for the 16v/Sporting.
Any suggestions would be appreciated.
Only solution would be to find a good second hand one (good luck) or you could look at a rubber manufacturer for a low production run (expensive). On the other hand, tape!
