Technical panda 169 body computer schematics and a MYSTERY
andy1
Rome
my car has an alarm (called med 5000 http://docshare01.docshare.tips/files/25501/255010995.pdf) that was installed by an auto electrician
i want to put the alarm on my new fiat 500,
but it has one major mystery,
it works but i can't enter its programming mode anymore (by turning car ignition key ON-OFF 11 times as per manual instructions)
i remember entering programming mode several times in the past,
what could have caused a change?
where can i find the schematics for that connector on the body computer?
it was a simple setup, just alarm sound and car lights flashing (no starter motor block with white cable)
I can't imagine there is any need for an alarm on a panda, it you really want one why not just get a new one fitted, or get the auto electrician to remove and reinstall the old one, although that might cost as much as a new one.
thanks for your answer,
it's because i have to give the old car away this monday...
alas, there is no time to leave the car to an auto electrician
no idea sorry
did spot
that if its already programmed its 13 times on and off ?
thanks,
i really appreciate your taking the time the go through the manual (y)
my bad for asking impossible questions (but i hope interesting ;))
i did try both 11 and 13 turns but no luck
anyway,
i have taken the alarm off the car,
plenty of time later to decide whether to use it on my new 500 or not
i love this forum (y)
Hi mates,
I´m looking for wiring of body Fiat Panda 2003 188a4000. Can anyone help with it please?
Thanks a lot
Hi mates,
Thanks a lot
which information do you require
most of the information is on fiat's elearn
However its not all in one place. Its separated, dash, lights, ECU and so on.
Each connector is list with pinouts. Which are normally right. The wiring colours are normally way off.
We have just done a oil pressure switch fault. The wiring colours on the three different diagrams I could find didn't match what was in the car even if converting into Italian
The ignition on/off method can fail if the ignition switch is getting clunky. What seems to be a single "on" could be two if it bounces.
