Technical Removing gear knob.
lowaaa
Seen a few posts on this matter, some say twist and others say pull.
No matter what I do, it just doesn't come off.. Anyone ever had that problem when it was really really tight? And how did you fix it ? Is it possible someone's super glued it down cause it really won't come off. Anyone got any clues on what I can do?
Thank you.
On such an old car it may well be a replacement.. thats been glued in place
My nephews 16v had obviously had it removed to change the gaiter.. now it came off on most 2nd and 4th selections :eek:
I used Epoxy.. : SOLID :)
you may want to cut the knob down the sides and SPLIT it... if you have a replacement
Thank you to everyone whose responded, I will try a hair dryer or something with heat. If that does not work, I will go with the pliers idea and hammer it out.
