can someone confirm the wiring of a DET3 as per this modified diagram from the ecumaster website.
their original wiring shows the 12v, ground and TPS connections just being wired direct to each other between the ECU and the DET3, i cant see that working???
i assume you only have to cut and intercept the MAP and CRANK sensor? the TPS, ground and 12v are commoned up to both the DET3 and the ECU?
thanks
thanks
