I would like to change my front and rear discs and pads. Can anyone advise the Fiat part numbers for the front & rear discs and front & rear pads?
Vehicle is a 500X 2.0 Multijet Cross 4x4 with a manual gearbox.
Since 2104 when the last Fiat offical
ePER Parts Catalog was available for anyone to purchase directly form Fiat for a modest cost they moved over to a USB Key parts system call Key
ePER (if I recall correctly) and this ran in parallel with Key eLearn (a USB based technical manual setup).
Key
ePER and Key eLearn deceased in late 2014 / early 2015 and Fiat went over to On-Line only parts and technical information. These are all subscription based from yeatly (very expensive) to hourly (the last time I checked).
There are sites around the web offerring more recent access to the latest/fairly recent parts informatio for post 2015 vehicles but they are heavily used with restricted access so when you do "get in" you can be easily "bounced" by another visitor.
I have found that for current and older vehicles that the OEM parts sites will correctly identify "their" replacement part and often list the Fiat/Alfa/... original part numbers for extra information.
As we go further back in time to the 60s/70s/80s and even early 90s then life becomes a little more difficult. e.g. For a Strada Abarth 130TC i can look up via the old microfiche slides a part number. In some cases in 2014 the Fiar
ePER parts listing would recognise the part number but show no details other than "out of production - no longer available". In other cases "part not found".
Summary: No silver bullet and often some research/howework is required.
