General Rear brake adjustment adjustment
tonyn
Hello all,
2004 1.2 ,ABS.
I have hade to change the rear nearside brake drum.
When ive fitted the new drum, its so tight, it nearly impossible to turn it.
To adjust the brake shoes inwards , to free it up, do i turn the cogged wheel on the adjuster upwards or downwards?
There self adjusting but need some slake in the handbrake cable to work properly
Wind them fully in and put the drums on
slacken handbrake cable by at least three turns
forcibly press the brake peddle loads of times clicking stops
retighten the cable
make sure the rear wheel rotate freely
check the handbrake action starts before the First notch
make sure the handbrake doesn't past the fifth notch
Its easy. There is too much false information floating around on the internet and YouTube
Hello all,
2004 1.2 ,ABS.
Its different for each side. Ones left hand and one right hand threaded
Just wind them both fully in by hand
If the drum doesn't fit easy you have assembled something wrong.
Thanks Koalar,
To wind it fully in , do i send the cogged wheel upwards or downwards?
I agree with koalar, the handbrake adjuster needs to be slackened first, then re-tightened at the end. It's underneath the handbrake housing inside the car (4 bolts to remove).
I would also prise the shoes out and manually wind the automatic adjuster back.
The cogged wheel is a ratchet - it can be forced the wrong way to loosen it, but I don't think it's a great idea, the ratchet wheel is quite soft and easy to damage.
Thanks Koalar,
You need to lift the latch and turn it so the bar shortens
From memory down but don't quote me
I don't really think about it as I wind them fully in before I assemble the rears
Agreed. The cog is soft you have to lift the spring steel latch first
Yes, I'm pretty sure it is down. You'll know as soon as you try - because you'll be forcing it against the ratchet pawl it'll be much harder to turn in that direction without prising the pawl out of the way first.
You might also be able to tell from close inspection which side of the teeth are sloped on the ratchet wheel.
