Haynes doesn't do one past 2012
This section of the forum is for up to 2012
Although similar they are also quite different
Best posting in the post 2012 section
On a 06 it involves
Disconnect the battery
Drain the coolant
Pop out the passenger airbag switch from the glove box
Remove the glovebox
Remove the passenger side dash screws just the ones underneath
Loosen the passenger airbag. Cant remember if there is also a screw under here but you don't have to disconnect it pop it back in place loose
Pop up the plastic ring holding the gear gaiter down
Lift out the section underneath
Remove the screws holding the gear lower trim in place
Remove the trim its tricky as there are also clips left side is always easy right side always fights you
On the left side there it a Black cover held on with tiny bolts remove.
You can now see the matrix and a plastic joining pipe
Remove the one screw and nut holding them together
In the engine Bay disconnect the two hoses. You will have to break the clamps off and replace with new clips
Remove the bolts holding the Black plastic cover down and pull the plastic pipes out
Inside the car pull the matrix out while lifting up the dash
Its a very tight squeeze but just doable without taking out the dash out fully by giving it enough wiggle room
Its been a few years so may have missed something out
