Technical Selecta gear selection cable
Richard Cooper
London
Hi all, purchased a Selecta for spares. it was advertised as having a broken gearbox. In fact the selection cable is seized. Haynes manual says undo both ends, and pull it through from the engine side. But it will not budge. Underneath it disappears behind the exhaust heat shield, and inside the car it looks as if it cannot be accessed where it passes through the bulkhead. Has anyone tried and solved this please? regards Richard
Thanks Blu, that's the conclusion i have reached, as it seems simpler than removing the interior. Of course, I'll find that having removed the heat shield, it's clamped on the inside!
