For the 1st time my standard 1970 L did not start from cold but it was 35° outside the garage. Normally starts 1st time every time.
Checked previous threads and found a post with possible solution from Mr Hobbler relating to this problem. So I
1. Took spark plug out and checked spark.
Good spark and very clean plug. ?
2. Disconnected coil and fuel pipe to carburettor. Put pipe end in jar and turned engine over. No fuel in jar ! ?.
3. Pressurised fuel tank. Took tank lid off put hand over open top and put compressed air gun nozzle between fingers and pulled the trigger. You've got to love the smell of petrol !!
Fuel filled the in line filter situated just in front of pump. Reconnected all pipes and cap.
Car started as if nothing had happened. ?
Car ran got warm then turned off. Here is the problem
I could hear liquid can only be fuel draining away !
No leaks but fuel filter has very little left in it. The car did start again but am a little apprehensive to use without knowing if this is normal and what caused the initial not starting.
Thanks for any help.
David
David
