TheAutopsy
- Joined
- Sep 12, 2017
- Messages
- 73
- Points
- 82
Hi guys. I come to you with someting that I found no answer to while searching.
I have a 1.1 SPI engine. And its leaking oil alot, and I cant find the source, and when I'm driving if I press the clutch the car wont iddle and will shut off.
So I was thinking about fixing the engine or puting a new one in. I found a 1.1 MPI engine from a 2004 punto that looks in good shape. My question is can you just put the MPI engine and will it work with the SPI ECU and wiring? Do you need to change something else.
By looking at it the diferences I saw was the injection (obsviusly) and the alternator was a bit diferente and the crank pulley was a bit diferrent.
Any help is appreciated.
