Technical clutch problem
andyjagzz69
hi I am new to the site as I am new to having a fiat. I have a 07 fiat multiplayers extravaganza and im having clutch problems. I have the clutch all the way down and its not changing gear, like its stuck in whatever gear I was in, it happened earlier, I was in first gear sat in traffic with clutch depressed all the way when suddenly it stalled and lurched forward a bit like id let go of the clutch. it was then stuck in first gear and I couldn't get it out of gear. I had to get out and rock the car , it then let me get it in neutral, start the engine and get it into first and move off. I had a new slave cylinder done today as it was leaking and thought that would sort it. it sounds like a pressure problem ? any advice would be welcome. thanks
