chinese radio
chinese radio
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
simon mattocks
Hi i have a 2009 Bravo and am installing a chinese all singing and dancing stereo,power up no problem if i connect permanent live and key wire from radio my prob is its on all the time.which is the ign wire from main double din plug there is only pin 5 or 7 in org harness and niether seems to do anything,thanks fr any advice
__________________
Fiat radios don't have a ignition switched supply but use the CAN bus for control. While you can buy a decoder, most peopl pick up a switched supply from the cigarette lighter / power socket wiring.
Robert G8RPI.
