Technical 500 engine issues .....continued [emoji23]
Baglady1990
One job always leads to another
west yorks
Can someone shed light on the faults I’ve detected? I’m booked into a fiat dealership on the 19th for a service I just need to know what I’m looking at as I’m still learning IMG_2744.JPGIMG_2745.JPG
As a guess I'd say there's been or is a misfire problem on cylinder 2 so possibly coil pack, plug, plug lead, valve, or injection?
yeah ive been reading a bit on this issue seems to be a common issue.... I cleared old faults yesterday once I figured out how to connect to engine
and today I struggled getting up a hill! im booked in with a fiat dealership anyhow... im not trusting back street places anymore!
I’m booked into a fiat dealership on the 19th for a service I just need to know what I’m looking at...
At a guess, I'd say a large bill (n).
Visiting a franchised dealer with a 9yr old car bought from outside the franchise might be an expensive exercise.
You'd do better going to your local equivalent of somewhere like this.
where are the cylinders in the engine? im having a hard time finding out online?
Here's a picture of a 500 cylinder block (actually a 1.4, but the 1.2 is similar).
The cylinders are the four large bores in the middle, you can also see the slotted passages through which the coolant circulates.
The head gasket sits on top of this, providing a seal between the cylinder block and the cylinder head.
To see inside the cylinders without dismantling the engine, you need a borescope, which is like an endoscope for engines. It's fed in through the spark plug holes (after removing the spark plugs). You can also do a compression test on the cylinders, which involves screwing a pressure gauge into the spark plug holes,cranking the engine, and seeing what pressure it makes. Both methods can tell you a lot about the engine's condition without dismantling, and can help work out whether your head gasket is still sound. The dealer may do one or both of these tests if an internal engine problem is suspected.
I hope this helps you understand what's going on; you've already had more than enough problems with this car, without needing any more.
I thought it was this IMG_2747.JPG haha how far down do I have to go?
Yeah I have almost had enough!! But tomorrow is another day..... the mechanic who the dealership use broke my new air box too!! Noticed today when I came to remove it..... back bracket broken right off!! It cost me 70£ on eBay too ... hay ho ...... on I go!!
It’s certainly worth trying coil pack and leads.at least it will rule them out. If it’s not you can get your money back on eBay by selling them on. You are getting more competent as time goes on and changing the coil pack is easy.
that's cause I actually enjoy it :D yeah off to euro car parts tom then ill be under the bonnet all afternoon! my guess is the coil pack but who knows..... ive been out and had a look it seems pretty straight forward.... watch this space :eek:
