Technical Coolant Leaking into Oil
ChromaticBattle
I did an oil change on my 77' X19 a couple days ago and the oil was colored green. My coolant is also green. The oils also smells of coolant. I believe it may be a head gasket leak where the oil and coolant passages are. I doubt the block is cracked but there is always a possibility. If there is any other plausible cause please let me know. I haven't taken this engine apart before so I am uncertain if any other gaskets can cause this problem. Any help would be great.
Get your local garage / shop to do a leak down test
