Technical Elearn / Eper - For Grande Punto TJET
Hey Guy
Im hoping someone can help. Ive been told about Elearn / Eper (not sure if they are same thing) On the forum a few times now to help with fixing my car.
I wanted to know:
1) Can I get a version that is specifically for fixing the GP 1.4 TJET , or is it just a grande punto overall sort of like a Haynes manual which doesn't cover the Tjet model.
2) If you can get specifically TJET model software - How do i go about getting this, i am not Mr computer savvy and I have been to downloads and thought i had it at one point as I now have an Elearn icon on my desktop but when i press it, it just does a no go pop up ( see pic) But again i have no idea if this was going to cover Tjet anyway.
Any help would be great - looking to change my thermostat / flush my heater matrix and would love some guidance.
eLearn is like an electronic Haynes manual and is model specific, so a Grande Punto one should cover all versions including T-Jet.
Depending where you got your copy from may explain how to make it work, but normally you have to burn it to CD (or mount the CD image as a virtual CD-ROM drive, I know a bit too tech savvy maybe!), then install it, but you still need to have the CD in your PC (or virtual CD mounted) to be able to run it.
ePer is FIAT's parts catalogue and covers all variants of all vehicles. An old (2006) version is available through the forum (http://eper.fiatforum.com/), newer versions can be found online.
thanks, for this, so is the elearn something you have to pay for and if not is there anywhere where you can learn how to burn it to cd or mount it virtually as you stated?
Here's the cook book:
- download the ISO file
- locate that file and right-click on it, choose the top option (Mount)
- you have now a "new" (virtual) CD drive that contains a bunch of files/directories
- double-click the "setup" or "install" file, this will install the software part on your computer
- once done, click on the program icon, select the language and the model you want
In your case, you already have the icon, that means that the software has already been installed. The error message is because the software doesn't find the necessary files it needs to execute properly; That is because the virtual CD is not there anymore: it has been unmounted OR has been assigned a different letter. To be sure, un-install the software using the configuration panel (or appwiz.cpl in the run window), mount the ISO file and re-do a fresh install. Next time you have to run eLearn, check first that the virtual CD is still there. Alternatively you could burn the ISO file to a CD (or DVD) but similarly you will need it to run the software.
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
Hey guys thanks for input from all of you and being patient. What's easy for some isn't always easy for others. I've done a video showing you where I have the problem as I do not see ISO files just RAR. But clearly shows where I just hit a brick wall.
[ame]https://youtu.be/RV1a9YkiEFg[/ame]
Download all 8 parts into the same folder, then point an unzip program such as WinRar or WinZip at part 1, then all 8 parts will unzip into one iso file.
Hey guys some Good news and poss bad news. So I believe I have done it (see pic). But the software doesn't seem to cover the 1.4 TJET model? Can anyone confirm if this is correct or have I gone wrong. Also side question the sometimes it says R.R on the info listings (see 2nd pic). Can anyone tell me what this means.
I'm trying to find specifically information on changing the 1.4 TJET thermostat as need to replace upper hose (slight leak where they join) so thought will change that also due to it being 10 year old and me.putting a flush solution in the system.
There's a version of eLearn online that covers the 1.4 T-Jet here:
http://4cardata.info/elearn/199/2/199000000/199000005
(Thanks to oldmanhouse for posting the link originally in this thread).
The R + R for the thermostat is described here:
http://4cardata.info/elearn/199/2/199000000/199000005/199000001/199000589
Thanks for this, really appreciate you taking the time to do this and thanks to oldmanhouse will really help alot, as have to do this job , always good to have a visual
Hey Pickwick,
I've noticed that in the explaining procedure parts it has links highlighted to other steps of the job which i assume are part of the job. it has Op. next to the link? is this to be short for 'Optional'?
In the past when I've used eLearn those links have always been part of the job.
If you change the language of the online eLearn to Russian "Op" becomes "Работа" - which translates as "Operation".
I have tried everything to get this Grande Punto eLearn to work with no success. I am currently redirected to a website that asks for username and password? Any help you can offer would be greatly appreciated.
The password is requested to "unrar" the file you downloaded, try " cardiagn.com "
BRs, Bernie
Slightly related. I stumbled upon this online parts catalog for the GP (and other Fiats), where you can check the OE numbers for pretty much any part, down to the nuts and bolts. But it seems right now the images aren't working:
For demo purposes, this is the front suspension parts list for the GP:
https://fiat.7zap.com/en/fpun/4c/199250201000-099/443/1+44301s00+3-0/
So if you ever wonder what is the real OE part number for something in the GP, you should be able to find it there very easily (even better when the images start working again).
I've found this one very useful too...
https://www.fiatdalys.lt/en
