- Joined
- May 1, 2014
- Messages
- 273
- Points
- 170
Hi guys, I need your help!!
After investigating a "sdong sdong" sound that shows up when I turn the steering wheel, I've discovered that I have a rough shock absorber top mount, almost stuck, and so the spring take some twist and then re-seat in its position.
There is some fast way to lubricate the top mount without dismount the shock absorber?
It's a doblo 263, and I suspect that the problem is due to the fact that the top mount is directy under the windscreen wipers, so it's exposed to the weather.
I obviously change them, but if I can find a temporary solution it would be better.
