Nowuries
Hi Fellow Fiat 500ers!
I purchased from Mr. Fiat and installed a set of no-name rear coilover shocks to replace the stock setup on my '70 Fiat 500 F. I have seen these from lots of vendors so I assumed they would be a fairly quick plug-and-play as I work to get my wee beastie back on the road. NOTE: The big difference from modern coilovers is there is no pre-load adjustment, i.e. I can't lower the spring from the top to allow for a given ride height, you can only adjust up from the bottom.
After install, I had the desired ride height, but after a short spurt of driving and a good bump, the springs settled into the suspension "cup" at the top and I lost about 1 inch, so now I am getting some rubbing, so I need to raise the spring some more.
The issue is that when I turn the lower adjustment nut, the whole shock turns because the spring is still really tight.... and yes, the top and bottom nut are tight.
So, since there is no pre-load adjustment option, I am wondering if you think removing the shocks and using spring compressors is the best option? Has anyone installed these? I saw a few posts on intentions, but no success/failure stories (yet). Here are the pictures of the item and installed.
