My back wiper is somewhat wobbly and i want to tighten it (if possible) for that i need to remove the tailgate internal plastic cover thing. But im kinda scare to just pull it off. Any advice? Or may be there is an easier way to tighten back wiper?
Ok. Any advice where is the best starting point for the removal of the covering? i.e. easiest first retainer to remove or best access point to the clips?
Wow! I never actually considered ambient temperature... Thanks for the tip! As it happens those are really hot days now where I live.I have done a bit of trim removal on my truck and the fiat Idea ...I use some plastic tire levers ....and a very slim spatula with a bit of masking tape wrapped around it ...it's a time consuming job ..best done in the full sun on a warm day , so all the plastic bits are softer so less likely to crack or snap ....
