Technical Heater switch bulbs
I’ve just done mine. You need to remove the hazard switch and the surrounding panel with the heater vents in it. Then remove the retaining screws for the heater control unit so that you can wiggle it about a bit. That will allow you to prise off the front panel from the heater control unit giving you access to the bulbs.
bulbs
