Technical Does my Doblo have a DPF?
stuartinlancashire
Lancashire
On a bit of a whim we’ve just purchased a 2007 57 plate Fiat Doblo Cargo on eBay that’s been converted to a mini camper.
It’s a 1.3 Multijet (like my Fiorino). I’m trying to figure out if it has a dpf, would I be correct in thinking that the dpf on this model is located underneath just after the flexi pipe? If that is the case then it doesn’t have one.
The other issue I’ve come across are that the LED’s in the instrument cluster for the EML and glow plugs are dead. Is a replacement cluster just plug and play or does it need to be programmed up? I was surprised it got through the MOT with a non functioning EML light, but apparently it’s only a testable item on vehicles built after July 2008.
I figured that our Doblo does not have a DPF as the handbook mentions they are only fitted on the 85 bhp and over models and ours is a 75 bhp.
