Hallo Everyone, I have a Doblo 1.3 multijet 2007 94k miles. I started to feel a lot of vibration when starting off in first gear or switching to a lower gear - engine brake. At first, I suspected clutch or dual mass but I had a look and I found a grease leak from inner cv joint offside (driver side). There is a lot of grease around the joint on the engine and chassis but I could not find any obvious damage to the rubber boot. Also, there is no other symptoms or noises.
My question is: is it possible that the leak could cause the vibrations or it's something in the clutch area?
