supacook2k
my washer jets dont work on my car! i pull the right hand stalk towards me but nothing comes out. i have filled the washer bottle up and the light washers work its just the ones on the bonnet. any help appreciated guys.
sometimes they get really blocked so an overnight soak in water may be needed. or just replace themChris_267 said:I had this with my passenger side one. i got a pin an cleaned out the hold on the jets an its started to work again, but its not the same as the drivers side. but works
custard boy said:sometimes they get really blocked so an overnight soak in water may be needed. or just replace them
you will find that cleaning the nozzles fixes it. I used a needle.
another Fiat design fault
it makes it a good buy if you're happy to repair little things.
