Hi guys,
GP 1.4 8V VVT - in MES I saw 2 values for camshaft timing on idle:
Desired cam position = -2 degrees
Real cam position = 0 degrees
Is this normal or bad? I expected zero for both parameters...No errors in MES, so I think that it's still in some "tolerance". Do you know your values? Is there some tolerance before ECU's reaction on it? Because by these parameters it looks that mine timing is little bit incorrect - camshaft is turned a little bit forward and should be set anti-clock-wise 2 degrees... What do you think guys? :devil:
