puntodad19
- Joined
- May 1, 2019
- Messages
- 99
- Points
- 82
What would be the gearbox oil for this car please?
Thanks varecrazy, where can i get a copy and roughly how much? What sort of laptop would i need for it, and would it run on xp?
Thanks Pickwick ecp lists an expensive synthetic castrol type.......dont know whats in there and whilst we looked underneath the car before buying there was a stain by the near side g/box oil seal where the drive shaft goes into the g/box. When pug welded and mot'd the punto is coming under the car port for a looksee/check etc..
Ah! Electric light bulb moment! I've now had two quick looks at my boy's 2012 1.4 Punto 8 valve because it seems to be leaking oil in this area. Both times it's been a "two wheels up on the pavement and me wriggling under in the gutter with a torch" job. I had reached the conclusion that it had to be either the inner joint boot - but just didn't seem right to me for that - or the gearbox seal. But if it was the gearbox seal there's far too much oil over the joint itself, and the boot, and not so much running down the casings under the shaft. If this selector is leaking it just might be the problem.I've done a quick search and the cheapest Tutela Technyx I found online was:
https://www.graysparts.co.uk/product/technyx 75w-85
1L - £10.94 inc postage
2 x 1L - £20.92 inc postage
If you have a local Fiat dealership it might also be worth asking them for a price?
When you get time to look at the nearside driveshaft check that the oil isn't coming down from above. The seal on the gear selector shaft can start to leak, then oil drips down onto the inner CV joint and spreads across the driveshaft. Here's a picture that I took last year before I replaced my selector seal - the view is through the nearside wheel arch (wheel removed):
Also there's a breather hole covered by a black cap on the top of the gearbox that can emit a bit of oil over time:
Of course it could be coming from the driveshaft seal as well as from above - which is what I found (driveshaft seal replacement is still on my to do list).
If in doubt clean up the whole area then monitor it to see where it starts to return.
hello everyone
can some one help me locate central lock wires and colors , as i am trying to install an ebay alarm . on a punto 2012
thank you
