Technical Small Rear Split door won’t open
PollyDee
Hello,
I have a 2006 Fiat Doblo High Roof with split rear doors. The central locking will open the larger left hand one, but the leaver on the smaller right hand door will not release it. It worked yesterday and I assume that i have broken the mechanism?
There is a wheelchair ramp in the back so access is difficult, but not impossible.
Any ideas please?
Hi. With the std roof van, from inside, you remove the screws holding the black trim piece and reach into door edge and pull up/down on the rods going to the locks. With open door it will be easier to look inside and find problem which can usually be fixed by diy/botch methods. Good luck.
Thank you very much. We will check it out this morning - fingers crossed!
Usually clip pulled on rod, cheap tat again
