General Advice
General Advice
berserker
Could someone please give me some advice about where the location of the following things are on my 2003 1.9d sx doblo
boost pressure sensor
solenoid vacuum control
thanks
on the logbook it says 1910cc
its a 1.9 diesel sx
on a diagnostic check it came up with error code p0235 boost pressure sensor
and also said clutch switch (this is not registering a fault code at the moment)
thats all it said
As stated on your other thread, the 1.9D does not have a MAP or boost pressure sensor or a turbo to produce any boost. What are you using to read the fault codes? Unless it model specfic like Multiecuscan the code descriptions may b isleading or codes incorrect.
As there is no turbo there probably is no vacuum solenoid either.
Robert G8RPI.
