Pedro Gonzales
- Joined
- Apr 5, 2019
- Messages
- 3
- Points
- 1
Hello All,
I live in Australia and have a 2007 Punto 1.3L diesel that fails to start every so often (around 1 in 12 starts). It never occurs when it is cold started, only after I have driven for 15-20 minutes and stop to go to the shops and then try to start it again. It's been happening for around 6 months and when it first started, there was a continuous clicking noise when the key was turned. Initially the mobile mechanic said the battery was on the way out, so I replaced it, but it didn't solve the problem. The next time it happened (and then started) I drove it straight to a mechanic and he said the fuel injectors needed soaking / cleaning, but this didn't solve the problem either, although the clicking noise has stopped and there is silence when the key is turned.
While writing this, I recall the left rear indicator isn't working as the globe keeps blowing but all other lights are ok.
Could it be the starter motor or solenoid that is next on my list to have looked at?? I look forward to your thoughts.
Peter
Peter
