just by chance I noticed the carpet in the boot was wet on the left side just near opening rear door. On inspection I saw a little mould on the metal.
Previously I battled leaks in an 05 Ford Focus so I had an idea of what to look for.
Comparing one side to the other I see the 'Factory water proof sealant' is applied by hand. So I got some Tec7 and expanded the around the Factory Seal and also other panel joins.
It is my strong suspicion the join under the indicator light is where this little leak occurs. Access is a bit tricky but I have hopefully sealed that seam.
Will put carpet back in and report back in a month.
Dan
Dan
