Hi all, I have an issue with the cruise control on my Croma (2005 1.9 8v). I've searched on the forum but I can't find anything similar, and I'm about out of ideas.
When you turn it on the message "Cruise control on" appears on the dash, however it won't accept any speed input.
The brake and clutch switches are behaving correctly.
When you select a target speed, no target speed appears on the computer when using multiECUscan.
When cruise control is off, the ECU knows which gear is selected. However 60% of the time that cruise control is activated, the ECU doesn't know what gear the car is in. It seems to come and go randomly.
The ECU is listing a "Generic Error" for the cruise control, however there is no indication of what this is or how to find out more.
I had my gearbox replaced with a recon one recently, and it was after that that I noticed the issue. I can't see any obvious unplugged wires or sensors on the gearbox. The gearbox type is listed as "Not learned". I don't know if this is normal or not, and I can't find any way to program it in.
That is a screenshot of multiECUscan, when the car was in 5th gear cruising at 80km/h. I was requesting the cruise control to hold speed but no input is being accepted.
Any help or advice that anyone can give would be greatly appreciated!
Thank you
Thank you
