Hi, I have a 2004 Seicento. I started running rough a couple of months ago so my garage to check for codes, there were none.
I changed the plugs, leads and ignition coils. It still ran rough. It dies when I depress the throttle.
When I sprayed carb cleaner into the throttle body it ran fine.
Next, I checked the signals to the injectors and they were all getting signals.
The fuel was flowing through the injector rail as I checked the schrader valve on the end and it was pumping out.
I removed the injector rail and then connected the fuel line and electrical plugs, I put bottles over the ends of the injectors and they were all pumping out fuel and all the bottles have the same volume of fuel.
It sounded better when on the driveway and would fully rev but when I try and drive it, it just dies and there is no power. Also now the EML is on.
Does anyone have any ideas?
