Hi Robbie. I've replied to your message but as it's the first PM I've ever done anywhere I hope it got through to you? Would you mind posting here to confirm?Sent a message I am new to this forum so sorry if I’ve got the reply/messages wrong
... Most engines have one or two positions, dictated by the piston position in relation to compression, in which they always stop ...
I'm not sure how "practical" you are Robbie? If you remove the starter then you can view the ring gear directly but you'd need to disconnect the battery and it is a bit of a "phaf" to get at the fixings. I was very worried that the radio would loose it's code when we did this on my boy's 2012 Punto 1.4 8valve but in fact the body module seems to remember it so it picked it up automatically on reconnection.Thank you for all the advise I will try anything until I can get confirmation of a replacement flywheel
Robbie
Becky, our Panda - 1.2 8 valve - is getting a new clutch tomorrow. So similar labour content in that the gearbox needs to come out. Quoted £290 (not inc vat I think) by our local Fiat independent, for the whole job and that includes the price of the clutch kit (Valeo).Thank you again if it was summer I might have had a go but at 62 and winter I think ill leave it to someone younger. The last bloke said that he did use a camera before he put the second new starter in and said he thought he saw damage (thought he did)? so I am going to go straight for a removal, inspection and replacement I think. By the way because I have a new starter fitted that is going to get wrecked if I don't get this flywheel sorted I suppose.
Any approx. figures for the job so I can compare with quotes
Many thanks
Robbie
Maybe his mechanic doesn't know how/hasn't the equipment to renew just the ring gear?We still don't know WHY you've been told to replace the flywheel ...
Maybe a little? a lot of the cost will be in removing the gearbox. Price of new flywheel Vs price of ring gear and labour to change - not too sure? If not paying labour on any of it it would be a cheap job. Still, be glad you don't live in the 'States. My sister pays "silly money" whenever a tradesman of any persuasion is needed. She lives in rural Massachusetts.No I didn't but thanks for the info, reference the flywheel that's what I have been told if the ring gear can be changed by a competent mechanic does that make the job cheaper.
Robbie
