I was about to fit an engine heater in the coolant hose today, so I removed the intercooler inlet hose to get more space - and got an unexpected oil shower!
The engine block front cover is leaking some oil, the idle has been poor a few times lately and the boost pressure and engine torque has had some mysterious digital dips from time to time. I performed some data logging recently and confirmed that it was the boost pressure that caused the behavior. However, it doesn't happen every time.
So, I called the local Fiat garage before and they suggested a clogged EGR valve, alternatively worn out turbo thrust bearing (axial lash). I suspect something with the crankcase ventilation. One issue is that those engines are extremely rare in Sweden, so no-one has any experience at all..
Problem: I cannot identify the EGR or any oil separator to the crankcase ventilation. Do anyone know if there is an EGR valve and where those components are located? What do they look like on this engine?
I checked the turbo with an endoscope and the impeller looks perfectly fine. I haven't managed to open the hose clamps on its intake, so I don't now if the bearings are worn, but I don't think so.
It has made 70000 km and we have had it since new.
Any other ideas?
Any other ideas?
