Hi there. I have a Brava 1.2. I'm trying to narrow down a front wiper problem before I do much disassembly. What I found is that the Stalk pull (Wash and wipe), Stalk Toggle Up (Single Wipe) and the Stalk Down full (Fast Speed Wipe Continuous) don't work. What does work is the remaining functions on the Stalk, namely The Stalk 1 down (Flick Wipe) and the Stalk 2 down (Slow wipe continuous). It should be noted also that the Washer does work on the Stalk pull, just not the Wiper. And also should be noted that all the rear wiper functionality works.
Is this a Steering Column Multi switch problem or a problem with relays inside the motor/relay package for the front wipers??
