Technical 1.6 Palio Weekender obd1 > obd2 elm327??
ODAN
Hi everyone
been having a issue where my car is having a pretty rough idle when its cold..
i have purchased a elm 327 device to do some diagnostics as where i live in South Africa the closest dealership is 250km away.
this model is a 2003 16v fiat palio weekender and uses the obd1 3 pin connector near ECU
i have purchased a obd1 to obd2 conversion cable
"the 3pin to 16pin with the 2 alligator clips to +,-
for the elm327 device but i cannot get any app "torquepro" etc or program "multiecuscan" to pick up the ecu to figure out whats wrong with the bigger picture
any help would be much appreciated
i just received another elm327 device and this one seems to work with my car
thank the heavens
i'm currently getting error
P0105 intake pressure sensor
P0110 air temperature sensor ?? " any ideas what this looks like or is located"
  • Like
Reactions: Tso
thank the heavens
Hi ODAN, Please kindly assist a brother out.
I am based in south africa as well, and i drive a Fiat Palio 1.2.. can you advice me on where i can get the correct elm327 device?
Thank you
Thank you
cant put up links but check aliexpress for a 327 v2.1 elm device and also get a fiat 3 pin connector brand name KWOKKER
managed to buy both from store AliExpress
HKKWOK's store
Thans ODAN,
Also a quick question, which protocol did you use to connect to your ECU?
