Hi guys,
I have Fiat Croma '06 with 1.9 110kW Multijet engine with DPF. Everything was OK since recently time when the car started not to start from the first time. Sometimes it takes several cranking cycles to start, then engine running rough at low RPMs and after that everyhing's fine again. Sometimes it starts well. But recently depending on the phase of the moon the car started not to start at all. It has to be pushed from outside and then quickly turns on and runs smoothly. After starting the car, frequently I get some special smell smoke from that flexible joint coming from the engine collector. By the way, when it's really cold outside metal knocking noise was heard from the bottom of the engine (??) - but quite rarely. Sometimes it shows DPF filter clogged but don't know whether the car starts regeneration itself.
Maybe any ideas or suggestions to start looking for the problem from? Thanks in advance!
